After Effects freeze when open a file :(
Mark Hildebrandt
on Feb 3, 2011 at 2:32:49 am
I have made an animation for a videoedit in AE cs4, which took around a day. Now it won't open i AE :(
The colorwheel just spin and spin and program writes "saving project". Does anyone know this problem and can it be fixed? See attached screendump.
<a href="http://i1.creativecow.net/u/168936/skjermbilde2011-02-03kl.03.11.23.png"><img src="//i1.creativecow.net/u/168936/skjermbilde2011-02-03kl.03.11.23.png" border="0" /></a>
Thanks for all help!
Best wishes,
Mark
Mark Hildebrandt
Re: After Effects freeze when open a file :(
on Feb 3, 2011 at 2:00:06 pm
it seems to load ok but when its finished its trying to save project (i dont know why . autosave is off)
Hope anyone can help
Dave LaRonde
on Feb 3, 2011 at 10:32:07 pm
Rather than opening the project file directly, try making a new project, and IMPORTING the troublesome project into it. It often works.
And looking at your screen shot, here's more advice: you REEEEEALLLLY need to get rid of all those mp3's if you intend to render an animation with an audio track. AE absolutely hates compressed audio. You need to convert those babies to aiff or wav files... and don't try to use AE to do it.
Dave LaRonde
Sr. Promotion Producer
Mark Hildebrandt
on Feb 3, 2011 at 11:54:57 pm
thanks!
i'll tried with the import thing. It didnt open :( thanks for the MP3 advice. i will follow it! I guess i have to start all over again with my project. Can other help me?
best,
mark
Dave LaRonde
on Feb 4, 2011 at 3:16:39 pm
[Mark Hildebrandt] "I guess i have to start all over again with my project."
Not necessarily -- if the import trick is successful, then reorganize folders as desired, save the new project file, save a copy, then get to work on the audio. You can use the Replace Footage command to substitute uncompressed audio for compressed audio, no other adjustments necessary.
Dave LaRonde
Mark Hildebrandt
on Feb 4, 2011 at 4:34:35 pm
thanks again :)
no, the import trick didn't work, som i just begin from start again now, it's "just" a days work, so i better get started... :)
but thanks for the advices!
