Plastic Faces
Davy McGuire
Plastic Faces
on Feb 3, 2011 at 1:01:28 am
Hi there,
I want to comp somebody's face onto a plastic action man-esque figure. How can I get the face to look plasticky and blend in?
Any ideas?
Davy
Jason Mettler
Re: Plastic Faces
on Feb 3, 2011 at 4:26:15 am
For starters, I would try making a displacement map with the original face. Then I'd add a light and mess with the material options of the layer.
Seems to me there will be several ways to acheive what you want to do.
Tudor "Ted" Jelescu
Re: Plastic Faces
on Feb 3, 2011 at 7:47:17 am
Is it shiny plastic or matte finish? If you can re-shoot the face (or if you did not shoot it yet) then try to apply some heavy makeup - to make the skin tones uniform and give the face an un-natural look. If it's shiny plastic you're after, use some sun tanning lotion (a pretty oily one) to give it highlights. The light is also very important- try to match the same feeling that the plastic action figure has.
In AE- you can apply the Remove Grain filter to smooth out the skin.
Tudor "Ted" Jelescu
Senior VFX Artist
