vibrating white color spectrum
Philipe Karlsson
on Jan 30, 2011 at 9:57:23 pm
Hello,
Im trying to achieve a vibrating effect in the white colors in a project.
I have been looking into different tutorials: flickering candles and street lights ec.t without any good results.
I would like to have almost a vibrating white color spectrum.
what would be a good and easy way to do accomplish this?
tips and inputs are much appreciated,
Cory Petkovsek
Re: vibrating white color spectrum
on Jan 30, 2011 at 11:47:26 pm
Without knowing what "good results" are to you or what a "vibrating effect" means to you, we can't be any help getting you there. White is not a color spectrum.
Taking a random guess at what you want, if I had an image with white in it and I wanted it to randomly cycle through colors I would use the "change color" effect. I'd set it to match white and filter it so it grabbed only my white object. Then I would reduce transform lightness to -50, transform saturation to 100 and put an expression on the transform hue with something like wiggle(1.2,180).
Cory
Cory Petkovsek
Corporate Video
Philipe Karlsson
on Jan 31, 2011 at 5:57:28 pm
Hi Cory,
I should have been more specific about my project.
But your guess is very correct. I never thought of the expression, I'll give it a try.
here is some reference material: (the lights in the background).
Thanks for you answer.
Regards/
Philipe
Tudor "Ted" Jelescu
on Jan 31, 2011 at 9:26:56 am
If I understand correctly, you are trying to achieve a super bright light- if that is so, you need to work in 32 bit - adding a glow will help to give that illusion.
Tudor "Ted" Jelescu
Senior VFX Artist
Philipe Karlsson
on Jan 31, 2011 at 5:59:47 pm
Hi Tudor,
I'll give it a try.
Thanks for your answer.
Regards/
Philipe
