Hyperthreading AE CS5 ?
Thomas Jaeger
on Jan 29, 2011 at 2:59:32 pm
Hello
I´m just rendering a composition on a MacPro (2010) with 12 core´s / 48 GB. In the taskmangerAE only use 12 core´s , and it seems, that AE don´t make use of hyperthreading ?!
I´m wrong ?
Regard´s
Thomas
Todd Kopriva
Re: Hyperthreading AE CS5 ?
on Jan 29, 2011 at 6:48:03 pm
Yes, After Effects CS5 does make use of hyperthreading. If After Effects isn't using more than a certain number of processors, it's because you have your Memory & Multiprocessing preferences set to reserve some threads for other applications and/or because you don't have enough RAM to feed more processors.
48GB is enough for 12 processes at the recommended 4GB of installed RAM per processor that will be used for After Effects rendering.
See this page for information about memory and performance in After Effects.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
