CS5 Keylight memory leaks
Dester Wallaboo
on Jan 19, 2011 at 5:24:30 pm
Haven't seen this on any forums. But I've noticed that Keylight in CS5 has tremendous memory leaks. If you do purely Keylight work for a couple of days, After Effects will just keep on eating up the RAM. Quitting out of AE doesn't solve the problem nor does clearing the cache. On a 12-core Mac Pro with 32GB of RAM, Keylight will cause AE to consume 24GB of RAM of a few hours of work. The only way to clear the memory is a reboot.
Dave LaRonde
Re: CS5 Keylight memory leaks
on Jan 19, 2011 at 5:29:00 pm
[Dester Wallaboo] "I've noticed that Keylight in CS5 has tremendous memory leaks."
Wow, I don't do enough sustained work in Keylight to even notice that. Can you document the behavior so you can file a bug report?
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
The more detailed, the better.
Dave LaRonde
Sr. Promotion Producer
Todd Kopriva
on Jan 19, 2011 at 9:49:23 pm
Have you installed the After Effects CS5 (10.0.1) update? It includes some memory fixes and new versions of several of the bundled third-party effects.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Dester Wallaboo
on Jan 19, 2011 at 9:50:36 pm
Yes.... running 10.0.1 and all plugs are current.
