cc composite
Michael Kocan
cc composite
on Jan 19, 2011 at 5:06:55 am
Im working with 32 bit exr's in a project and wanted to use cc composite. I noticed it was an 8bit effect and wasnt sure if it was okay to ignore, or if there was a similar effect for 32 bit?
Walter Soyka
Re: cc composite
on Jan 19, 2011 at 3:13:35 pm
[Michael Kocan] "Im working with 32 bit exr's in a project and wanted to use cc composite. I noticed it was an 8bit effect and wasnt sure if it was okay to ignore, or if there was a similar effect for 32 bit?"
Don't ignore it -- using an 8-bit effect with 32-bit footage in a 32-bit project will clobber your dynamic range. See the HDR Compander effect [link] for a technique to minimize the damage.
Perhaps some judicious layer duplicating with AE's regular transfer modes would let you accomplish the same thing without compressing and expanding your dynamic range?
As a side note, many of the Cycore's effects are available in 32-bit versions as part of the Cycore FX HD bundle [link] (though CC Composite is not one of them).
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Michael Kocan
Re: cc composite
on Jan 19, 2011 at 8:04:31 pm
Ahh..Okay, I have seen that effect before but never knew what it did. So there arent any real 32-bit effects that work the same way as CC Composite?
Todd Kopriva
Re: cc composite
on Jan 19, 2011 at 9:35:18 pm
Check out Solid Composite.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Kevin Camp
Re: cc composite
on Jan 19, 2011 at 9:42:47 pm
boris's composite effect may be 32-bit.
the calculations effect can do a lot of the same things as cc composite, but it is 16-bit (not sure if that helps at all)...
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
