rendering problems
Sam Needham
rendering problems
on Jan 18, 2011 at 4:47:44 pm
Hello,
I'm having real problems with after effects cs3. I have a bunch of very short avi's in 1280 X 720 (25fps) format that I'm trying to render out into a movie in ae. I have no problem rendering them out as a full movie, the only trouble is the quality suffers greatly, no matter how uncompressed, best, full resolution etc I have the settings. I've tried so many combinations it's driving me nuts. I would just do this in premiere but I'm going to need to add png watermarks and stuff later. Can anyone please help?
Sam
Tudor "Ted" Jelescu
Re: rendering problems
on Jan 18, 2011 at 4:58:03 pm
What compression do the .avi files use. What compression are you trying to render at? Do you have the latest CS3 updates installed?
Tudor "Ted" Jelescu
Senior VFX Artist
Dave LaRonde
on Jan 18, 2011 at 4:59:18 pm
And since it's 720p, is the frame rate actually 50p when you think it's 25p?
Dave LaRonde
Sr. Promotion Producer
Sam Needham
on Jan 18, 2011 at 6:27:23 pm
Thanks very much for the lightning responses. The avi's were render out first from maya (the compressor is called Microsoft Video 1, and the animations were all 25 fps) They were all rendered out at HD 720. I don't know if this changes the frame rate, but I just looked on after effects and there's not even an option to set the comp to 50 fps, just 59. something. And yes I have all the updates.
What am I doing wrong?
Walter Soyka
on Jan 18, 2011 at 6:40:32 pm
[Sam Needham] "The avi's were render out first from maya (the compressor is called Microsoft Video 1"
Egads. These must look awful -- Microsoft Video 1 tops out at 16 bits per pixel (not 16 bpc, 16 bpp!). You should use just about anything else.
For 3D renders, I always use image sequences.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Dave LaRonde
on Jan 18, 2011 at 6:44:40 pm
[Sam Needham] "...the compressor is called Microsoft Video 1, and the animations were all 25 fps... What am I doing wrong?"
Not a thing. You're just suffering from a Maya person who, for the sake of more compact storage, rendered in a codec that even Microsoft considers to be obsolete. It might look okay in a viewer, but not for what you're doing.
This person has no clue about the concept of using intermediate codecs, i.e. codecs that don't degrade image quality as the media files make their way through the production process.
The problem will be solved when -- not if, but when -- the Maya person re-renders all these short clips as uncompressed AVIs... not converting them to uncompressed AVIs, but actually taking the time to re-render them as uncompressed AVIs.
Anything else will be a mere band-aid, and the image quality will suffer. If more storage is needed, hey -- what's a 1 TB external drive go for now? A hundred bucks, maybe?
Don't cheap out on image quality. You already know what happens when you do.
Dave LaRonde
Tudor "Ted" Jelescu
on Jan 18, 2011 at 6:48:45 pm
There ya go- Dave and Walter covered everything. My suggestion, ask for file sequences (tiff, tga...) to be sure you get uncompressed stuff.
Tudor "Ted" Jelescu
Senior VFX Artist
Dave LaRonde
on Jan 18, 2011 at 6:54:43 pm
I'll second the idea of a tiff or tga sequence.
Dave LaRonde
Walter Soyka
on Jan 18, 2011 at 6:57:57 pm
[Tudor "Ted" Jelescu] "My suggestion, ask for file sequences (tiff, tga...) to be sure you get uncompressed stuff."
Just a small piece of pedantry -- TIFF (which I have heard stands for "Thousands of Incompatible File Formats") can use either lossy or lossless compression. I wouldn't put it past someone who renders to MSVC-encoded AVIs to use a lossy variant!
Make sure you specify "uncompressed" or "lossless" when you ask for TIFF files.
TGA files are always lossless, though they are limited to 32 bpp.
Walter Soyka
Sam Needham
on Jan 18, 2011 at 8:16:24 pm
Yes, you're right, I'm an animator not a renderer. The thing is, the avi's look fine until they go into after effects. I'd be quite happy with the quality they are at the moment but ae degrades them much worse.
Thanks.
Dave LaRonde
on Jan 18, 2011 at 8:44:18 pm
I recommend sharing your hard-won wisdom about intermediate codecs with your Maya person. For both of you, this won't be just a gig but a valuable learning experience.
Dave LaRonde
Sam Needham
on Jan 19, 2011 at 12:47:54 am
Now I rendered an avi from maya using no compression. The avi plays in slow, staggered time in my media players. I then rendered this out uncompressed in AE and the image is the same (which is that problem solved, thankyou) but the playback is still slower and staggered than it should be. Is this normal?
Sam
Walter Soyka
on Jan 19, 2011 at 1:14:54 pm
[Sam Needham] "I then rendered this out uncompressed in AE and the image is the same (which is that problem solved, thankyou) but the playback is still slower and staggered than it should be. Is this normal?"
Yes. Intermediate renders like this are meant to preserve the image for additional production use, not to be played back. The data rate for uncompressed video is very high, and a single hard drive can't read the data back from disk fast enough to play in real time. If you go through frame by frame, you'll see that everything is there.
If you want to play it back in real time, you could transcode your lossless intermediate to a more playback-friendly codec like H.264 or WMV. These formats are intended for playback, not for production use.
Walter Soyka
