"Flattening" Layers with Effects
Cody Wright
on Jan 9, 2011 at 9:29:47 pm
Hey guys,
I have a motion graphics project that I'm needing to send off to the client in which he only needs the project files, not a rendered Quicktime clip. The client doesn't have the effect plugins that I'm using, and I'm wondering if it's possible to "flatten" the effects to a layer like you can do in Adobe Photoshop with the Flatten layer command?
Any help? Thanks.
Tudor "Ted" Jelescu
Re: "Flattening" Layers with Effects
on Jan 9, 2011 at 10:05:38 pm
Depends what effects you are using - some effects react to the composition (other layers, camera move and so on). You may not get the desired final look if you render just those layers- which is the only way you can do this in AE.
Tudor "Ted" Jelescu
Senior VFX Artist
Dave LaRonde
on Jan 10, 2011 at 4:29:59 pm
There really isn't any really neat & tidy way to handle such a situation. If sending the project file only is an absolute must, you either need to re-work it to eliminate the necessity for your third-party plugins, or the client has to buy them on his/her end.
If neither can be done, you'll have no choice but to prerender those things that use your plugins.
It's just not easy to do, I'm afraid.
Dave LaRonde
Sr. Promotion Producer
