animating at 24fps delivering job at 59.94
chico nguyen
on Jan 6, 2011 at 12:44:05 am
Hey guys,
Sorry to bring up a subject that's been beaten to death here on the forums.
But I need some help here with the proper way to convert a 1080 24fps animation for a client to 59.94 quicktime in After Effects.
I know that:
1. You import/intepret the 24fps animation as 23.98 in AfterFX
2. Render that out with fields for proper 29.97fps in the output module.
What I'm unsure about is the next step to 59.94.
Do i bring in the 29.97 footage and interpret this differently to render out 59.94? Or do i just drop this 29.97 footage into a comp that is 59.94 and render this out?
Pleasse help. Much appreciated to all.
Chris Wright
Re: animating at 24fps delivering job at 59.94
on Jan 6, 2011 at 1:56:49 am
if there's no audio, just interpret as 23.976, drop into make new comp icon, render out with fields 3:2 pulldown cadences.
this is how I would do it if there's synced up audio.
--mac
if you have mac's compressor, conform to 23.976fps. It will both change the audio and the video and stay in sync. then in AE, interpret as 23.976 and drop into make new comp icon. render out with fields 3:2 pulldown cadences.
--pc
if you have pc, you can still sync up in AE without having to use separate audio software. interpret as 24fps. drop into make new comp icon.
right click timestretch 100.1001001
Now from the Layer Menu select Enable Time Remapping. This last step is very important as it triggers After Effects to use a very high quality audio re-sampling technique
Precomp it and place it into a 23.976 comp. render out with fields 3:2 pulldown cadences.
http://technicolorsoftware.hostzi.com/
chico nguyen
on Jan 20, 2011 at 7:54:49 pm
Thanks Chris for the thorough response.
Really appreciate it. I normally don't deal with layoffs and final output.
I just find all these standards really lame as HD was supposed to "solve" all of the issues with Standard Def standards.
Dave LaRonde
on Jan 6, 2011 at 3:56:27 pm
[chico nguyen] "...I need some help here with the proper way to convert a 1080 24fps animation for a client to 59.94 quicktime in After Effects."
The big question: 59.94 WHAT?
At 720, you can go 59.94P, but at 1080 you should go 59.94i. If 1080, do what Chris says, because 1080 29.97 upper-field-first is the same thing as 59.94i.
Dave LaRonde
Sr. Promotion Producer
chico nguyen
on Jan 20, 2011 at 7:52:21 pm
Hey Chris.
Thanks for the response. I just needed re-assurance on this.
These HD standards are insane. I thought HD was supposed to fix the standards confusion and not add to it.
Dealing with PAL and NTSC was bad enough.
The whole 720p at 59.94 is really bizarre as it adds hold frames.
I delivered a huge ESPNU package in 720p 59.94 in 2009.
1080i 59.94 is really dumb in my opinion as it should just be called 1080i 29.97 Upper Fields first.
Thanks again for the confirmation
