automation for QUICK FADES?
Caspar Stracke
on Dec 30, 2010 at 2:35:24 pm
Hi all -
Imagine this:
I have a wild flickering image sequence with altering frames (It's long, 10 minutes..)
Now I realized - when projected large- it's actually too much. Flickering *WAY* too much and gets on everybody's nerves ;-)
So I decide to strobe it a bit (5 frames) But now my question is: any trick to quickfade 2 frames on each end with the next image to make even that sequence smoother?
Any trick *greatly* appreciated!
Caspar
happy new year!!!
Dave LaRonde
Re: automation for QUICK FADES?
on Dec 30, 2010 at 4:42:15 pm
My older daughter, who grew up hanging around a TV station, refers to such an animation as "seizure video". I reeeeeallly think you're going to want to use something longer than a 2-frame dissolve.
You owe it to yourself to run a test BEFORE you revise the entire project. Use various frame durations. No fooling -- you don't want to get hit with a Homer Simpson "Doh!" moment. You can save Opacity Animations Up & Down of various durations Effects Presets.
Dave LaRonde
Sr. Promotion Producer
Caspar Stracke
on Dec 30, 2010 at 5:49:17 pm
Thanks Dave, charmed to get not only an technical advise but also an artistic/aethetical one.
I left out the fact that these single images are already form a coherent sequence so it's not THAT wild as described.
Sorry, I didnt understand Did you mean "from" or "to" the effects presents? Went thru all the presets and could not find any transparency up-down Effect.
I assume these effects work between two layers, correct? So how could I oscillate Transparency from layer 2, say in a frequence of 5 frames? (or more, in case I make a special version for your daughter ;-)
best,
Caspar
Dave LaRonde
on Dec 30, 2010 at 6:56:49 pm
There isn't a transparency effect. You have to animate the Opacity property with keyframes, and then you can either copy & paste keyframes or save the animation as an effect preset.
That's one way to do it. If you're not up on expressions, I don't recommend you try another way to do it.
Dave LaRonde
Chris Buttacoli
on Dec 30, 2010 at 6:07:48 pm
Are the images all of equal length? If they are, an expression should do the trick. Something... like...
(assuming all are 2 sec images on a 30fps comp with a 4f fade)
Create a new black solid and put it as the top layer.
Set opacity keyframes at frame 0 to 100, frame 3 to 0, frame 57 to 0, and frame 60 to 100. This will cause the fading in and out to black over 4 frames.
Now Alt-click the stopwatch for opacity and write: loopOutDuration()
Click out and you're DONE.
Caspar Stracke
on Dec 30, 2010 at 7:44:00 pm
FANTASTIC. That was exactly what I needed.
Much thanks Chris!!!!
