Typography Audio Trouble
Walter Marshall
on Dec 4, 2010 at 1:23:42 am
Greetings,
This is my first post to the forum, but I have visited many times for tips. I run into this problem from time to time, and I'm just curious to know if anyone else has this issue.
When creating typography I notice the audio skips and does not play in sync with waveform. The audio waveforms are at times not even present. Then there are times when the audio will play and skip to a totally different place within the audio track. I closed out of the waveform view,opened in the viewer, and the audio continues to skip around. I don't have any other programs open that would use ram. Not really sure about this one. Any advice would be appreciated.
System:
Imac
20"
2.16 GHz Intel Core 2 Duo
3 GB 667
Version 10.6.4
AE CS5
Walter Marshall
Twitter.com/WalterVMarshall
Dave LaRonde
Re: Typography Audio Trouble
on Dec 4, 2010 at 3:52:05 am
I suspect you like to use compressed audio: mp3's and ac3's, for instance; you can't do this in AE.
You simply MUST use uncompressed audio files like aiff and wav. Use something like Quicktime Pro to convert them. That's why I like QT Pro so much; it's like a multimedia Swiss Army Knife. Best 35 bucks you'll ever spend.
You also MUST have the free update to AE 10.0.1.
Dave LaRonde
Sr. Promotion Producer
Walter Marshall
on Dec 4, 2010 at 8:38:37 pm
Thanks Dave.
The update corrected my issue. Also, I will grab a copy of QTPro.
Have a great Christmas,
Walt
Walter Marshall
Walter Soyka
on Dec 4, 2010 at 1:50:14 pm
See this technote: Audio playback, RAM preview scrambled or jumps around
This occurs when using AIFF files with After Effects 10.0. You should update to 10.0.1.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Walter Marshall
on Dec 4, 2010 at 8:40:30 pm
Thanks Walt
Walter Marshall
