Filename burn-in on render
Daniel Frome
on Nov 30, 2010 at 1:32:33 am
Hi guys;
I've got 300 or so odd clips that I need to render into quicktime movies. I would like AE to display (in the quicktime movie) the filename of whatever I've rendered.
Is there such a script that I could apply in batch to these 300 or so files? Secondly, how would I go about installing/activating such a script?
Sorry - AE noob here.
Chris Wright
Re: Filename burn-in on render
on Nov 30, 2010 at 3:39:07 am
Queue_Comp_Sections.jsx
http://www.crgreen.com/aescripts/
http://technicolorsoftware.hostzi.com/
Kevin Camp
on Nov 30, 2010 at 3:52:43 pm
if the script doesn't do what you need, a simple way to create this is with an expression in a text layer.
i'm not sure if you needed the name of the comp, or the name of a layer within the comp, but either way, you would create a new text layer and add an expression like this to the the text>source text of the text layer:
// this will put the name of the layer just bellow the text layer in the text layer
thisComp.layer(index+1).name
// this will put the name of the comp in the text layer
thisComp.name
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Kevin Camp
on Nov 30, 2010 at 4:04:06 pm
if your source file for the layer was a different name than the layer, you could use this:
// places the source file name in for the layer bellow the text layer into the source text
thisComp.layer(index+1).source.name
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Daniel Frome
on May 11, 2011 at 3:06:52 pm
Kevin -
I never got to thank for you for your help!
Is there a way to automate this process for say...several hundred clips? For example -- importing a whole bunch of files, creating comps for each file with a text layer over each one and then applying this expression to burn-in the comp name?
