Aja 10-bit RGB codec with After Effects
Dan Goulder
on Nov 29, 2010 at 12:24:29 am
Can anyone please tell me if After Effects can both import and, after dust busting, stabilization, etc., export footage using the Aja 10-bit RGB 4:4:4 uncompressed codec, without in any way modifying the color bit depth? I've had no luck with this using AE 6.5, even when altering the preferences as recommended by Aja tech support. The exported footage should be able to be placed back on an Aja 10-bit RGB preset timeline in Final Cut without needing to be rendered. If this situation has been successfully addressed, in what version of After Effects was it fixed?
Thank you.
