Crack Layer in Half?
David Vaipan
on Nov 25, 2010 at 4:42:48 am
Is there any way to simply split a layer along the middle, but jaggedly, like a cracked egg? And then have it separate?
Matt Ratcliffe
Re: Crack Layer in Half?
on Nov 25, 2010 at 5:29:48 am
If I was going to do a basic crack through the middle, I would split the layer at the point of the animation is needed, use the pen tool to draw a mask all around the top (or side) half with a jaggered edge through the middle - this would leave a finished half designed to your liking. Then duplicate the layer and switch the mask from Add to Subtract to invert the mask, giving u the second half. Now you can easily transform the positions of each layers up or down, side to side, or whatever.
Hope that helps!
David Vaipan
on Nov 25, 2010 at 6:04:18 pm
Yes! So much so simpler than what I almost did. Thanks! It looks great!
Roland R. Kahlenberg
on Nov 25, 2010 at 8:17:27 am
I'm sure you'll find a way once you've watched this tutorial -
http://library.creativecow.net/articles/toula_jesse/Custom-Shatter-Maps.php
HTH
RoRK
AE Training in South East Asia. AE templates for sale and rental. Click here for more
