Export a 1080x1920 comp from AE to reconstruct a FLA file! XFL crashes!
Renato Silva
on Nov 19, 2010 at 5:40:43 pm
People all over the world,
I need your help! My problem is the following:
I need to transform an AE comp into a FLA file. The comp is 1080 by 1920 (vertical) and I tried to use the XFL file but I get a 1080 by 1080 FLA file when I open the XFL in Flash.
I tried in AE to export a sequence of PNG to import it into FLASH inside of a movie clip, but I only can do this on the first 100 frames then it crashes all the time.
What can I do?
PLEASE HELP! I WILL SEND YOU A PAIR OF HAVAIANAS from Rio de Janeiro.
Thanks a lot!
Todd Kopriva
Re: Export a 1080x1920 comp from AE to reconstruct a FLA file! XFL crashes!
on Nov 20, 2010 at 6:26:56 am
You could rotate the 1080x1920 90 degrees, export it, and then rotate the result in Flash.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
