Color management
lars pedersen
Color management
on Nov 19, 2010 at 9:15:22 am
What is the most common color space used in post production/motion graphics and what is the common workflow to ensure that the color stays the same as the client wants (etc a .psd file with source materiale)??
Walter Soyka
Re: Color management
on Nov 19, 2010 at 3:02:21 pm
[lars pedersen] "What is the most common color space used in post production/motion graphics "
This depends on your target display medium. For HDTV, use Rec. 709. For NTSC, use SDTV NTSC. For PAL, use SDTV PAL. For digital cinema, either P3 or XYZ.
[lars pedersen] "what is the common workflow to ensure that the color stays the same as the client wants (etc a .psd file with source materiale)?"
Set your working space as above in Project Settings to enable color management in After Effects. Assuming the PSD file is tagged with a color profile, AE will handle the color management for you seamlessly in the background.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Todd Kopriva
on Nov 20, 2010 at 5:34:26 am
There are resources linked to from this page that give step-by-step instructions for using color management.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
