Curing warping in Twixtor
Joe Orange
on Nov 16, 2010 at 10:45:16 pm
Warping that comes about from slowmo-ing in Twixtor can be significantly reduced by turning down motion sensitivity but this directly causes dropped or duplicate frames, so one issue is corrected at the cost of the other.
Is there another or better way of curing warping without such side affects?
Dave LaRonde
Re: Curing warping in Twixtor
on Nov 16, 2010 at 11:09:33 pm
You must be trying to slow down a shot by a large amount. How much?
Most of the effects that people use to fix things in AE aren't really cut out to work miracles. They work best within reasonable bounds.
Dave LaRonde
Sr. Promotion Producer
Chris Wright
on Nov 16, 2010 at 11:38:57 pm
twixtor pro can accept mattes and vectors. It's way better. plus, you don't want to warp more than 50%. you should instead, re-warp it again.
http://technicolorsoftware.hostzi.com/
