interface problem when exporting to avid dnxhd codec
Frank Feijen
on Nov 11, 2010 at 6:12:58 am
Hi there,
So i want to render my compositiion to a quicktime, avid dnxhd 120 with alpha.
I recently upgraded from cs3 to cs5, and this worked flawlessly in cs3.
But now the window where i should set up the codecrelated stuff seems all messed up. Therefore i'm not even able to select alpha export.
Any clues?
John Cuevas
Re: interface problem when exporting to avid dnxhd codec
on Nov 11, 2010 at 1:52:08 pm
Hope someone has an answer for this, I'm having the same problem also on multiple computers.
Johnny Cuevas, Editor
Kevin Camp
on Nov 11, 2010 at 5:03:22 pm
there was a recent update to the avid le codecs (now v2.3.2):
http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=372311
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Frank Feijen
on Nov 11, 2010 at 6:57:54 pm
Wow, amazing.
And i just thought that by recently uphrading my avid-soft, all codecs would be brandnew as well.
Thanks a lot.
John Cuevas
on Nov 11, 2010 at 7:12:19 pm
Thanks Kevin, that did the trick...
