Line drawing 'sizzling lines'
Jay Falk
on Nov 10, 2010 at 8:49:02 pm
Can anyone give me a pointer on how to make a cartoon's lines 'sizzle' or 'shimmer' like you can see here:
Is this just two slightly different versions of the same image or is there a way to do it from one image? I think it is unlikely people spend the time to make two of everything, it's a very common effect but I have no idea how it is done.
Any advice greatly appreciated.
Kevin Camp
Re: Line drawing 'sizzling lines'
on Nov 10, 2010 at 9:17:54 pm
the scribble effect can do something similar with the right settings, but you'll need to have vector as masks to use it.
a simpler approach might be to try the turbulent displace effect. you'll need to animate the evolutions and lower the size and amount until you start getting a similar look.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Jay Falk
on Nov 10, 2010 at 9:41:03 pm
Thanks Kevin!
Now you mention it turbulent displace seems quite a logical place to start - didn't cross my mind, which is a bit worrying :)
I'll give that a go right away - I also thought it may be possible by keying out the background kind of badly and then placing a plain white solid behind it - I had to key a wall out from behind an interviewee a while back and his clothing was a very similar color. Along the way I remember dealing with similar shimmering edges on the subject.
Thanks for such a swift response - I'll report back on the result.
Best
Jay
Kevin Camp
on Nov 10, 2010 at 9:44:36 pm
if the art is keyed, say line art from illustrator, you could also try the roughen edges effect.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Jay Falk
on Nov 10, 2010 at 9:49:05 pm
More Thanks!
Sounds like this will work out one way or another - really appreciate the tips.
I'll post on the results - couldn't really find much on this anywhere.
Jay
