Problem Moving Object
Bobby Dorrance
on Nov 9, 2010 at 4:30:23 am
Hello,
I've recently had this issue where I cannot move a object with the cc sphere plugin attached to it. I also am unable to zoom with a camera on the object. When I try to move the sphere, it only moves the wireframes around it. I did a screen capture of me going through the process. Here is the link for that
. Thanks to all responses.
Bobby D
Simon Bonner
Re: Problem Moving Object
on Nov 9, 2010 at 10:42:32 am
I don't have a copy of AE on this machine, but am I right in thinking you need to set up CC Sphere to use the composition camera?
Simon Bonner
youtube.com/simonsaysfx
Adriano Moraes
on Nov 9, 2010 at 1:39:39 pm
I made a simple test here and the same thing occourred.
But only when I applyed the CC sphere to a Shape Layer.
When I apply it to a Solid or to an Image everything works fine.
It must have something to do with shape layers. I don´t know but maybe the fact that it is made out of stroke and fill and is not actualy a solid coordinate based thing. But now I guess I´m triping.
Let´s leave the explanation to Todd.
Try using a solid. It will work.
ninguem
////http://cargocollective.com/ninguem/
Adriano Moraes
on Nov 9, 2010 at 1:55:43 pm
And by the way thanks!
I´ve never thought of applying cc sphere to a shape layer (thought it would be the same as applying it to a solid)
Now I´m playing around and the possibilities are awesome!
Cheers!
ninguem
