Comp Scale
Eric Lahm
Comp Scale
on Nov 7, 2010 at 4:23:32 pm
ok, so I spet 3 days putting together a video project for my website. Everything looks great, except it's fairly pixelated, which is weird because all of the images I used are huge, and I rendered it with the best settings. I've decided that it's because I rendered it at too small of a comp size (320X240), so now I want to go back and scale it larger.
My question is, is there a way to scale everything in the project (including scale & position keyframes) uniformly and relative to one another? or do I have to go back and scale each item individually and adjust all of my keyframe positions accordingly?
Adriano Moraes
Re: Comp Scale
on Nov 7, 2010 at 6:00:04 pm
Hi there. You might wanna try the Scale Composition script.
Under: FILE > Scripts > Scale Composition.jsx
(I believe it comes with after effects. I have so many scripts now that I can´t really tell.)
Hope it´s what you´re looking for.
Cheers.
ninguem
////http://cargocollective.com/ninguem/
Eric Lahm
Re: Comp Scale
on Nov 7, 2010 at 7:17:26 pm
That worked great! I knew there had to be a simple way of doing that! Thanks!
Roland R. Kahlenberg
Re: Comp Scale
on Nov 7, 2010 at 7:31:44 pm
It sounds more like you're not sure what you're doing.
If you want serious assistance, I suggest that you provide more info on the settings for your Render & Output Modules. Do include details on the size of your source footage.
Cheers
RoRK
AE Training in South East Asia. AE templates for sale and rental. Click here for more
