mpeg 2 with sound
yotam monk
mpeg 2 with sound
on Nov 5, 2010 at 10:58:04 am
At the moment, i cant export in any way, an mpeg file with sound...,only in separates files,m2v and mpa,silly question i know...
but i cant...
working on after effects cs5
thanks
yotam
Ryan McAfee
Re: mpeg 2 with sound
on Nov 5, 2010 at 1:14:27 pm
If you are working with a PC try exporting it out as a Video for windows then use Adobe Media Encoder to change it to MPEG-2.
There are many other ways but try that.
Ryan McAfee
Moon Community Access Television
http://www.MCA-TV.com
Michael Szalapski
on Nov 5, 2010 at 1:40:11 pm
You need to set the multiplexing.
However, as kinda already mentioned, it's best to render uncompressed out of AE and use something else (like Adobe Media Encoder) to do your final compression. AE can't do multipass compression. Multipass compression gets you better-looking video at smaller file sizes.
- The Great Szalam
yotam monk
on Nov 5, 2010 at 4:14:33 pm
thanks for the advice...,im trying to save some time...,can i import the composition into premier and then export the mpeg with sound stright from premier,those r long clips were talking about
thanks again
Michael Szalapski
on Nov 7, 2010 at 8:48:17 pm
You can import AE compositions straight into the Media Encoder and/or Premiere, but it's essentially launching an instance of the AE renderer...
I wouldn't do it, because I have a workflow that goes well for me. I would suggest you do a test and see what works best for you.
- The Great Szalam
