syntheyes- after effects intergration
alex shackleton
on Nov 4, 2010 at 7:05:01 pm
Hi
Im working on adding a camera solve from syntheyes into after effetcs.
The track on Syntheyes is flawless however when i put the exported syntheyes file onto the original footage in after effects the null objects are slightly jumpy and dont seem to fully lock on the footage. Ive checked that the frame rate matches but still cant seem to get it solid in after effects.
Any help on this would be great
thanks alex
Chris Wright
Re: syntheyes- after effects intergration
on Nov 4, 2010 at 7:43:49 pm
make sure the aspect ratio is the same. Are you positive you have a perfect track? Place a primitive in there, like a cube, and see if it slides on the floor. Have you setup your coord system? Did you use a wide angle lens(remove distortion) watch the tutorials. You can delete probable bad tracks with its menu button. remember you need like 10-12 tracks to solve, and often need manual tracking on hard solves.
http://technicolorsoftware.hostzi.com/
alex shackleton
on Nov 6, 2010 at 6:46:00 pm
Ive cleaned up the track and set up a coord system, works perfectly now thanks for the help
al
