Moving object with animation
Paul Woodvine
on Nov 4, 2010 at 11:41:06 am
I have an object that I have added multiple position points to in 3d space. I want to drag the object to another position but without distorting any of the position animation. So basicaly I want to move my object accross but still want it to move in the same way. Hope this is clear?
Michael Szalapski
Re: Moving object with animation
on Nov 4, 2010 at 1:43:31 pm
Select all of your position keyframes (and make sure your current time indicator is sitting on a keyframe) then, in the position property in the timeline, make your adjustments. All the keyframes will be moved that amount.
- The Great Szalam
alex dinnin
on Nov 4, 2010 at 4:58:24 pm
Or.. get a null.. and parent your object to the null.. then move the null as you wish !!
