After Effects Warning
Cutter Johnston
on Oct 24, 2010 at 12:05:03 am
I am getting this warning when I perform a RAM preview of about 160 frames with the audio added into the animation:
After Effects warning: Q::MonitorMixerFailure fails with message: AsioHost::IntBuffers()failed
Has anyone seen this? Can someone point me in the direction of a solution?
Butch Golden
Re: After Effects Warning
on Oct 26, 2010 at 5:22:05 am
Need more info.
What version of CS? What sound card, and what opsys. Further, what file format is the audio in?
ASIO is probably not the problem but a unhealthy mix of the factors above can be.
Cutter Johnston
on Oct 26, 2010 at 12:02:52 pm
Thanks Butch. I will examine the "unhealthy mix". If I can not solve it I will return to the forum.
