Get shift when moving from video to still of same image
David Keefer
on Oct 22, 2010 at 2:42:58 pm
I was wondering if someone has figured out how to solve a problem I've been struggling with for a couple days. In AE-CS3, I'm trying to move seamlessly from a video clip created in AE to a still image (a menu created for Encore CS3) of the video's final frame, but I get a shift each time. The still image seems to enlarge.
The still image is being used in Photoshop to add buttons for the menu, and then imported into Encore where the shift occurs.
Any help would be much appreciated. Thanks.
David K
Dave LaRonde
Re: Get shift when moving from video to still of same image
on Oct 22, 2010 at 3:54:55 pm
Are you certain that you're keeping pixel aspect ratios consistent from application to application? Especially when working in Photoshop?
Dave LaRonde
Sr. Promotion Producer
Todd Kopriva
on Oct 22, 2010 at 4:45:29 pm
As Dave suggests (and as I suggested on the other forum where you asked this), I think that you are converting to square pixels as you go through Photoshop.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
