Creating a bird's eye view of a hurricane
Haik Katsikian
on Oct 19, 2010 at 9:13:46 am
I'm looking to create a realistic (as much as possible) bird's eye view of a hurricane, as if pictured from a satellite.
I looked up this tutorial but couldn't exactly get it to work. My time displacement was causing all sorts of funky looking clouds.
http://forums.creativecow.net/thread/2/936129#936510
Does anyone have any ideas on how to create one?
As always, your help is always much appreciated,
thanks
Haik
Michael Szalapski
Re: Creating a bird's eye view of a hurricane
on Oct 19, 2010 at 6:34:37 pm
If you do a search on the forums for "hurricane" you will find a few threads discussing it. This one may be good.
- The Great Szalam
Haik Katsikian
on Oct 20, 2010 at 3:55:48 am
Hey!
Thanks for the quick response. I tried this tutorial but my clouds end up looking like they are in a nuclear haulucaust when I apply time dispacement..
Would you happen to know why? or have any other suggestions?
Thanks again!
Haik
Tudor "Ted" Jelescu
on Oct 20, 2010 at 8:01:38 pm
You could use a good actual hurricane sattelite image to create a displacement map for the same image and slightly rotate that.Use the techniques described in the tutorials below http://library.creativecow.net/jelescu_tudor/3D-from-2D-image_AE/1
Also, use some of the techniques in this tutorial to create some movement in the clouds:
http://www.videocopilot.net/tutorials/animating_a_still/
Tudor "Ted" Jelescu
Senior Compositor/VFX Artist
