Importing layers
Philana Chiu
Importing layers
on Oct 18, 2010 at 7:44:47 am
I'm attempting to import several illustrator files (with the layers still intact). The first file works perfectly, but when I attempt to import the next file, it keeps reimporting the first. I tried to close out AE in the hopes that it would fix it, but nothing is working. Any ideas?
Dave LaRonde
Re: Importing layers
on Oct 18, 2010 at 3:24:21 pm
Sorry, I'm a little confused. Is your problem that you don't get the layers in Illustrator documents, or that AE is only letting you import the same document, no matter which one you import?
Dave LaRonde
Sr. Promotion Producer
Philana Chiu
on Oct 18, 2010 at 8:44:55 pm
It's the second case. If I import something called Design1 as a composition, and then attempt to import Design 2 also as a composition, it will continuously reimport Design1. So I end up with 2 compositions of Design1.
Dave LaRonde
on Oct 18, 2010 at 9:58:16 pm
Try importing the importing the Illustrator documents in a different way. I like to simply navigate to the folder containing the desired footage, then dragging it right into the AE project window. It works like a charm for me.
And if you haven't turned off your machine for quite a while, you'd be surprised at the therapeutic benefits such a simple thing can bring to AE.
Dave LaRonde
Philana Chiu
on Oct 19, 2010 at 6:15:24 am
Turning off the computer did the trick. I wonder why it didn't work when I restarted the program, but anyways, thanks! XD
