reshape and open gl in ae cs4 cs5
steffan kasler
on Oct 17, 2010 at 10:15:23 am
Hello,
this is my first post here. i love this forum it helped me out a lot.
so here is the thing.
i have used the respahe effect in after effects cs4 a lot in a project the strange thing is when i render or preview it without open gl the reshape effect doesnt seem to work so good. it has strange glitches.
so i used open gl to render.
now i switched to ae cs5 but now i cant render with open gl anymore. its the same project and the same computer but it always says open gl not supported.
i tried different setting for the graphic card memory but it wouldnt change anything. the render output without open gl is glitchy in ae cs5. i have attachted two images that show how it looks in the preview window
this is open gl off
this is open gl on
Roland R. Kahlenberg
Re: reshape and open gl in ae cs4 cs5
on Oct 18, 2010 at 8:50:59 am
If you have your installer disc and a non-64 OS, you will be able to install CS4 on the machine. In the future, never ever delete or install over previous versions of AE. Always keep the old versions around. They are very useful for such occasions as well as when you need to send an AEP out to someone with a lower version.
For now, check that you have the latest OpenGL drivers for your card and CS5. Check the adobe site for a list of compatible cards.
HTH
RoRK
AE Training in South East Asia. AE templates for sale and rental. Click here for more
