Importing Boujou to After Effects
Brad Ballew
on Oct 15, 2010 at 8:25:02 pm
So I tracked some footage in Boujou and exported my camera for After Effects. I have done this a few times and everytime I bring the camera into After Effects, the composition is running at 25fps. So I have to slow my video down to about 95% to make it match up. Why is this happening and how can I fix it?
Tudor "Ted" Jelescu
Re: Importing Boujou to After Effects
on Oct 15, 2010 at 9:06:30 pm
Check the sequence to camera output fps rate in Boujou. If you have that set to 29.97 or 30 (whatever the footage you're tracking is at) you should be fine.
This may also help:
http://www.videocopilot.net/forum/viewtopic.php?f=4&t=4519
Tudor "Ted" Jelescu
Senior Compositor/VFX Artist
