Keying a bad footage!!
Sala Sultan
on Oct 15, 2010 at 4:15:27 am
Hello everyone!!
Keying a bad image is challenging... After applying keylight in After effects and the footage is keyed I got the bad compression effects, you know, when you play the footage different blocks and noise appear and disappear frequently.
The image didn't look like that before keying though.
Do you know what causes that effect?
Also does it have a solution?
Thanks!!
Sala
Michael Szalapski
Re: Keying a bad footage!!
on Oct 15, 2010 at 1:13:08 pm
The blockiness is in your original footage. You just can't see it. Here's why: it's compressed to keep the file sizes tiny, but the compression is designed to be invisible to the human eye. Problem is, it's not invisible to the computer. If something is compressed, the more processing done to it, the more obvious the compression becomes. Check out this post by Dave LaRonde explains it well.
This post covers getting a better keylight key.
Here's a tutorial that should help too.
Also look for a tutorial on super-tight junk mattes.
- The Great Szalam
Sala Sultan
on Oct 16, 2010 at 12:40:24 pm
Thanks alot Great Szalam!! This is really helpful!
You have a great day :)
Sala
Sala
