Image Stabilizer
William Roy
Image Stabilizer
on Oct 9, 2010 at 9:00:13 pm
Hello,
I try to stabilize a video I shot, Only, There is a small problem. I want to use the last frame of video for the rest of the stabilized video, But when I ' EX executes, He always uses the first frame of video for stabilized. So I was wondering how to stabilized with a different image than the first?
Thank you
Chris Buttacoli
Re: Image Stabilizer
on Oct 10, 2010 at 5:30:28 pm
Hard to completly understand you, but what about going to the last frame and running the stabilizer in reverse? The motion tracker has both foward and reverse buttons.
William Roy
on Oct 10, 2010 at 7:39:53 pm
yeah but it's always the first frame who's stay still. I want the last one to be still
Chris Buttacoli
on Oct 12, 2010 at 3:26:08 pm
If you go to the last frame of the clip and create a new tracker for stabilization, and run the tracker backwards, the last frame will remain still. Now when you go back to the timeline and play it forward, the last frame will be in its original position.
Hopefully this helps, otherwise I am not grasping what you mean by this "stay still" stuff.
William Roy
on Oct 13, 2010 at 5:27:57 pm
That's what i did, but anyway I find another way
thanks for your help
