Interlacing footage
James Henry
Interlacing footage
on Oct 8, 2010 at 7:16:49 am
Hi All,
I'm just wondering if there is an easy way to create an exaggerated interlaced footage look, the most similar example I can think of is this (whenever there is an on-screen movement by the band):
I am mixing this footage with progressive footage - I did think about just transcoding the footage I want to an interlaced format but I'm not sure if there would be a better way to do this in AE
Any help would be much appreciated!
Chris Wright
Re: Interlacing footage
on Oct 8, 2010 at 9:20:16 am
1. there's re-interlacer by revision that uses motion encoding, or
2. you could try my program I made in AE. It uses timewarp's pixel motion shutter blur to create a difference matte driving a griddler effect so that it only affects heavy motion.
3. There's probably a practical approach too such as doubling the frames with optical flow then placing the frames back into original fps comp forcing the frames to turn into fields then rendering out fields and then re-importing back into AE with fields off.
ae cs3 aep
Dave LaRonde
on Oct 8, 2010 at 4:05:29 pm
Personally, I'm thinkin' Displacement Map.
Dave LaRonde
Sr. Promotion Producer
© 2018 All Rights Reserved
