Baywatch text
Kevin Allar
Baywatch text
on Oct 7, 2010 at 3:46:19 pm
I'd like to create see-thru text, any thoughts? After FX CS 5.
thanks
Kevin Camp
Re: Baywatch text
on Oct 7, 2010 at 4:02:32 pm
there's always the opacity setting which would make the text semi-transparent...
if you wanted the text to mask out the video, there are a number of ways.
  • place the text above the video and set the video layer to use the text layer as a track matte using it's alpha.
  • place the text above the video layer and set the text layer's blending mode to stencil alpha.
  • add the set matte effect to the footage layer and chose the text layer's alpha as the matte.
  • add compound arithmetic effect to the text and choose the footage layer as the second source.
  • place the text under the footage layer and check the 't' option in the modes panel for the footage layer.
and i'm sure there are at least five more ways...
are any of these how you want to make the text and footage work?
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Kevin Allar
Re: Baywatch text
on Oct 7, 2010 at 4:42:59 pm
Thanks Kevin, I'll give them a go!
Kevin Allar
