Ortibiting particles trails
Dan Pietreanu
on Oct 6, 2010 at 6:33:50 pm
Hello creative people.
I have created a particle trail ( with particular) that follows a null object . I've made the null object move in an eliptical fashion... sort of... using this expression:
r=thisComp.layer("Null 1").effect("Radius")("Slider") // radius;
u=time*200 // angle;
x=r*Math.cos(degreesToRadians(u));
y=(r/8)*Math.sin(degreesToRadians(u));
z=0;
c=[thisComp.width/2,thisComp.height/2,0];
add(c,[x,y,z])
The problem is that I dont know how to tilt it, using a degrees system or whtaever could be used in this case , something like this:
. Any input would be more than apreciated.
Regards
PS: I'm using After Effects CS4
Kevin Camp
Re: Ortibiting particles trails
on Oct 6, 2010 at 7:07:17 pm
try making the particle system layer 3d (and ignore the warning message), then rotate the layer as needed.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Dan Pietreanu
on Oct 6, 2010 at 7:35:26 pm
Thank you for answering so quickly, as you can see I'm a noob. I will try that and post the results here. Again thank you for taking your time to answer this thread :-)
Regards
Michael Szalapski
on Oct 7, 2010 at 1:57:37 pm
You can also check out this conversation over at VideoCopilot. Someone there seems to have a similar issue and several solutions were suggested.
- The Great Szalam
