Cartoon Effect - Stopped Working
Jared Isham
on Sep 28, 2010 at 7:51:05 pm
I'm trying to complete some VFX work for a client where I am using the cartoon effect. When I loaded After Effects today every clip that has the cartoon effect applied to it makes the video turn black. When I select the "toggle transparency grid" it shows that there is no video being displayed at all.
I tried removing the effect and reapplying it, but that did not work either. I even tried importing different footage and to no avail.
Is this something that is going to require that I do a reinstall?
I am working on a PC with After Effects CS4, all updates have been installed and nothing has changed since now and the last time it was working.
If I can't get this effect to work any suggestions on how to achieve the "Cartoon" look without the filter?
Jared Isham
Stage Ham
http://www.stgham.com
film. video. web media
Todd Kopriva
Re: Cartoon Effect - Stopped Working
on Sep 28, 2010 at 10:59:48 pm
The Cartoon effect can use the GPU. Perhaps there's an issue with your video card. Does this project work on another computer?
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Jared Isham
on Sep 28, 2010 at 11:02:02 pm
Haven't tried it on another computer as I don't have access to one at the moment. Currently my OpenGL setting is turned off, I also tried it with it turned on - no success. Everything else works the same with my graphics card, I'll do some diagnostics to see if I can find an issue.
Jared Isham
Stage Ham
Todd Kopriva
on Sep 28, 2010 at 11:12:41 pm
I was suggesting toggling the property in the Cartoon effect that determines whether or not it uses the GPU. The property is called 'Performance'. It's toward the bottom.
Jared Isham
on Sep 28, 2010 at 11:15:26 pm
Genius - that was it. Thanks a million!
It is labled in AE CS4 as "Performance: (check box)'Use OpenGL When Available'"
Jared Isham
Stage Ham
