Easy way to reverse stacking order in timeline?
Mike MacKenzie
on Sep 27, 2010 at 6:15:06 pm
Hey everyone...
I suspect this is an easy one, but I cannot figure an easy answer...I'm hoping someone out there can.
Let's say I have a 100 layer comp, and I want to reverse the stacking order of the layers in the Timeline, so that the top layer is on the bottom, the 2nd layer is second from the bottom, etc. (again I mean Timeline stacking order, not position).
Is there a simple way to do this, or do I have to manually drag each layer down to where I want it on the Timeline?
-Mike
Motion Graphics Designer / Art Director
Boston, MA
System:
Mac/Leopard
2 x 2.8 GHz Quad-Core Intel Xeon
10 GB 800 MHz DDR2 FB-DIMM
Steve Blacker
Re: Easy way to reverse stacking order in timeline?
on Sep 27, 2010 at 6:40:03 pm
Click the layer you want to be the first layer, shift click the layer you want to be the last layer, then cut (ctrl/cmd+x) and paste (ctrl/cmd+v). Voila!
It's only work if you'd rather be doing something else...
Mike MacKenzie
on Sep 27, 2010 at 6:44:08 pm
Thank you, this was super-easy and worked like a charm!
What a great, time-saving shortcut. I am naming my firstborn Steve Blacker, even if it's a girl!
Boston, MA
System:
Mac/Leopard
Steve Blacker
on Sep 27, 2010 at 6:45:58 pm
Ha ha ha ha!
Glad to help.
Jeff Herring
on Jul 15, 2016 at 4:12:22 am
...and 6 years later this sage advice still works. Thanks guys! You all stick rock as always!
Mauricio Saleh
on Sep 9, 2015 at 4:45:55 pm
Feel a little fool with this solution--- :/
Steven Perry
on Apr 15, 2017 at 1:47:37 am
So I basically need to do the same thing, except for shapes within a single shape layer.
I have a bunch of lines of text on a page, and I'm doing a trim paths, to make it look like it's written on, but they need to move in the opposite direction, top to bottom, not bottom to top.
For a bunch of parallel lines, this same copy past function doesn't work within a shape layer... :/
Roei Tzoref
on Apr 15, 2017 at 11:46:05 pm
unfortunately no. even stacking order shortcuts (Ctrl+[ Ctrl+] or Ctrl+Shift+[ Ctrl+Shift+]) don't work with shape content (or type content for that matter). do us all a favor and ask for it here: http://www.adobe.com/products/wishform.html
in the meantime, maybe you will find this script useful: http://aescripts.com/bq_shape-layer-navigator/
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Martin Jaeger
on Sep 27, 2010 at 6:47:20 pm
Select the bottom-most layer in your comp then shift-select the top-most layer in your comp (which should select all the layers). Copy. Delete. Paste. The stacking order should be reversed.
Todd Kopriva
on Sep 27, 2010 at 11:43:43 pm
All this and more:
"Change the stacking order for selected layers"
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
