After Effects Error: Bad Tracked Memory ID
Randy Burleson
on Sep 27, 2010 at 4:08:59 pm
I am getting this AE error: After Effects Error: Bad Tracked Memory ID (23::34)
Does anyone know what this means or how to fix the problem?
It keeps crashing AE and I am not sure what to do to fix this.
AE CS4
Mac OS 10.6.4
Michael Szalapski
Re: After Effects Error: Bad Tracked Memory ID
on Sep 27, 2010 at 7:21:28 pm
From Mylenium's AE Error Code Database:
Message interpretation:
An internal allocation process resulted in a faulty request for memory from an area not currently controlled by After Effects.
Possible causes:
Seems to be related to handling compressed media. CoDecs may use fixed memory areas to store there compression algorithms which may then end up outside the reach of the host program.
What sort of video files are you using? You might try converting them to lossless Quicktime or AVI files.
- The Great Szalam
soheil sigurd
on Oct 6, 2010 at 8:45:40 am
Hello,
I keep getting "Bad Tracked Memory ID" error. I am woring in CS4 Mac. And the project is only using taga files.
Any solutions? I need to finish this project and I cant do anything because I keep getting th error and crash.
Can anybody help? Pleaese.
Michael Szalapski
on Oct 6, 2010 at 9:47:41 pm
The After Effects 9.0.3 update fixes some memory issues. Try it and see if it helps.
- The Great Szalam
Luke Milton
on Jun 5, 2013 at 2:54:22 pm
Did you get a solution for this? - I am getting the same error and I can't edit my work.
Luke
