After Effects won't import Premiere Pro Project
Robert Doobay
on Sep 23, 2010 at 1:18:39 am
OK, i have cs5, and I like to edit videos in premiere before transferring them to after effects. this method was fine until i upgraded to cs5. then whenever I have a premiere pro project that is version cs5 that i want to import to after effects, the program starts wigging out and a thing pops up which says:
After effects: aegp plugin premiere pro import: Can't load premiere pro project, this version is not supported. (5027 :: 12)
anyone have run into this problem before? anyone got a solution?
thank you very much, guys!
Tudor "Ted" Jelescu
Re: After Effects won't import Premiere Pro Project
on Sep 23, 2010 at 8:35:06 am
this may be obvious to you, but I have to ask- are you using AE CS5 and PremierePro CS5?
Tudor "Ted" Jelescu
Senior Compositor/VFX Artist
Robert Doobay
on Sep 24, 2010 at 2:32:44 am
yes i am. its all cs5
Tudor "Ted" Jelescu
on Sep 24, 2010 at 8:27:30 am
Weird- I use CS5 for a while now and import Premiere to AE- never had this issue, only when I tried importing a CS4 Premiere to AE CS5 once. I solved that by importing to AE CS4 saving and then opening that in AE CS5. Try posting this on the Adobe forums.
Tudor "Ted" Jelescu
Robert Doobay
on Sep 25, 2010 at 4:05:44 pm
So what you're saying is that I need ae cs4 in addition to cs5 in order for this to work?
Dede Oji
on Nov 4, 2010 at 12:45:33 pm
Doobay, its nothing strange...i have the same issue...did u get a solution cause i need help too. Cheers..
DEDE
Jay Yolo
on Apr 29, 2011 at 1:36:50 pm
In AE, choose "Import Multiple Files" instead. Voila!
