3D clipping plane
rich nosworthy
3D clipping plane
on Sep 22, 2010 at 3:05:18 am
Hi guys,
am wondering if theres anyway to create a clipping plane for a 3D comp with another 3D layer. Kind of like the way CC sphere can render a foreground and background or both.
I can get the layer to clip everything behind using the 3D layers blend mode set to silhouette alpha and then intersect it with the 3D comp but no idea how to get it to just clip everything in front.
Any ideas
Bartek Skorupa
Re: 3D clipping plane
on Sep 22, 2010 at 6:55:14 am
Put your layer with the "silhouette alpha" on top of everything and then place an adjustment layer below it. Don't apply any effect to this adjustment layer. The adjustment layer placed below 3d layer will cause the 3d layer above it to ignore the 3d space and use order of layers.
Bartek Skorupa
Warszawa, Poland
rich nosworthy
on Sep 28, 2010 at 8:20:16 pm
Thanks guys,
have been working on another project, but will have another look at this tomorrow hopefully. Thanks for the suggestions, will give it a go!
Cheers
Cassius Marques
on Sep 22, 2010 at 12:21:37 pm
What Bartek said will make it clip everything in that 3d layer's area. To clip only what's in front of it:
duplicate your main composition(in the project panel), then:
1- tint the 3d clipping layer white, and the 3d comp black.
2- Put these two comps (your main comp, and the tinted one) in another comp.
3- Set the main comp to use luma inverted of the tinted comp.
4- Precompose that (let's call this Matte1). Bring in the 3d layer. Set Matte1 to use the 3d layer alpha's matte.
5- Precompose this and use it again as an inverted alpha matte to your initial 3d comp.
Guess it will work, if I got something wrong, maybe this can at least give you some direction.
bart stevens
on Nov 9, 2010 at 8:14:51 pm
Cassius,
Can you clarify your directions? I've tried following your steps, but I'm having some difficulty.
I have a very simple composition.
I have text animating on a circular mask with the center at 0,0,0.
I have no problem setting up my " Z-plane" and making the positive Z space (or further from my camera) masked out.
I used a square comp with white solid and placed it in 3D space at 0,0,0.
It's above the text path in the composition and set it to silhouette alpha.
The obvious challenge is making the positive (or closer to the camera) masked out.
Let me know if you have any ideas,
B
Cassius Marques
on Nov 10, 2010 at 9:12:39 pm
Hi Bart,
I'm sorry but I don't know how to be more clear, maybe my instructions are hard to get at first, but they are all there. What version of AE do you run? maybe then I can create a simple project to illustrate.
The goal of what I was saying is that... if you can mask what's behind something. You can use THIS as a matte to get the opposite.
bart stevens
on Nov 10, 2010 at 10:05:10 pm
Thanks for the response Cassius,
Yeah I understand the concept, but was having a hard time getting it work. I found a method to get the results I needed anyway.
Thanks for the help.
-B
