Keylight not keying white
Chris Armstrong
on Sep 19, 2010 at 4:48:53 am
I'm trying to key some footage which has a white background. Using a luma key isn't cutting it, so I wanted to try and use Keylight.
Unfortunately Keylight isn't working on pure white. If I try another color in the clip it works fine, but as soon as I select the white background it won't key at all.
Is there something I'm doing wrong?
Todd Kopriva
Re: Keylight not keying white
on Sep 19, 2010 at 11:39:46 am
Keylight isn't for keying white. Keylight is for keying colors, especially blue and green.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Dave LaRonde
on Sep 20, 2010 at 2:33:34 pm
Keying against white works only under a limited number of circumstances. For example, if you want to key Darth Vader holding a black cat, you can probably get away with it.
Otherwise, it becomes a complex mix of effects, masking and rotoscoping. Keying against white is a very bad idea.
Dave LaRonde
Sr. Promotion Producer
