Using RAM preview settings while rendering ?
Andy Joseph
on Sep 18, 2010 at 3:12:33 am
Hi again,
I'm trying to hold my unusual 'RAM preview settings' such as 'FPS & Skip frame' while rendering a final movie but its not happening. I also selected "preserve frame rate when nested or in render que" in comp settings > advanced options.
I'm able to change a frame rate while rendering but there's no option for skip frame in rendering settings window.
Experts please help me achieve this.
Andy
Todd Kopriva
Re: Using RAM preview settings while rendering ?
on Sep 18, 2010 at 4:48:01 am
Why not just set the frame rate to half in the render settings if what you're trying to emulate is the skipping of every other frame in a RAM preview?
BTW, you can save a RAM preview.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Andy Joseph
on Sep 18, 2010 at 7:07:37 am
Thanks for you support, Todd.
Ok now i don't have any problem in setting a frame rate but i'm unable to set that 'Skip' option (next to 'frame rate' option) in render settings. Can u tell me how to go about it ?
Todd Kopriva
on Sep 18, 2010 at 7:14:53 am
If you have a 24fps composition and you skip 1 out of every 2 frames, it's the same as setting the composition to 12fps.
So, if you want to get the result of skipping frames in render settings, do the arithmetic and set the frame rate accordingly.
Andy Joseph
on Sep 18, 2010 at 7:52:50 am
Ok lets say i play at 50 fps & set 'skip' to 10 frames. Can you tell me the frame rate settings that can alone get the same effect?
Andy Joseph
on Sep 19, 2010 at 2:22:20 am
Hi Todd,
I'm eagerly waiting for your reply, its really important. I'm unable to get it right, pls do the calculation.
Andy Joseph
on Sep 25, 2010 at 5:34:52 am
Hi Todd, I'm still waiting can you pls help me.
