Render Color Issues
Dirk D. Lopez
Render Color Issues
on Sep 15, 2010 at 10:55:32 pm
I'm having trouble properly rendering out the colors I see in AFX to the colors I see in my finished renders. As seen here:
http://cl.ly/2Ot4
Notice the yellow in the quicktime render looks washed our, faded.
See everything looks great color wise until in AFX. I would like to render out my animations in the ProRes format. I have tried all of the 422 codecs. I have also tried multiple settings that are not working under color management: NONE, HDTV, GAMMA NONE, GAMMA AUTOMATIC, etc….
When I render out in the Animation Codec it looks correct but see I would like to use the less bulky Pro Res codec so I can save hard drive space.
Thanks for the help!
Jeffrey Kaplan
Re: Render Color Issues
on Sep 16, 2010 at 12:03:25 am
Try
File > Project Settings . Click the Check Box marked "Match Legacy After Effects QuickTime Gamma Adjustments"
Render - and you should be OK.
Jeff Kaplan
Point 360 WEST
Animation & VFX Department
http://www.point360west.com
Todd Kopriva
on Sep 16, 2010 at 6:54:47 am
This is what color management is for.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
