AE only renders one frame of comp
Jurjen Versteeg
on Sep 15, 2010 at 8:51:08 am
Hi There,
I have a really annoying problem:
I'm working with a really simple scene including some 3D layers, a moving camera, some particular particles and color correction adjustment layers.
As soon as I selected my work area bar and hit render it gives me the apple lollipop and after a couple of minutes (don't see the the render bar processing) I only got one frame rendered in my final MOV.
What is going on? I'm working AE CS5.
Thanks in advance,
Jurjen
Jurjen Versteeg
Re: AE only renders one frame of comp
on Sep 15, 2010 at 9:34:53 am
Don't see the option to edit my previous post:
I found out that disabling the multiprocessing option fixed the problem. Which still leaves me with a mysterious render issue.
Michael Szalapski
on Sep 15, 2010 at 1:31:59 pm
What are the specs on your machine?
- The Great Szalam
Markus Schille
on Nov 15, 2011 at 8:55:20 am
Having the same problem, seems to have something to do with multiprocessing. Turned it of and it works, But I would really like to be able to use all my cores for efficiency...
Did anyone find a solution, or report a bug to Adobe?
