copying and pasting AE layers
chris straus
on Sep 9, 2010 at 8:12:54 pm
simple question, but i have no answer. why does after effects reverse the order of layers when copying/pasting? eg. i have 4 layers, LAYER 1 (on top), LAYER 2, LAYER 3 and LAYER 4 (on bottom). I want to copy and paste those layers, but it pastes in as LAYER 4(top) down to LAYER 1 (bottom). is there a way to paste in the same order as copied? thanks.
Dave LaRonde
Re: copying and pasting AE layers
on Sep 9, 2010 at 8:24:00 pm
Select layers in the order you want them pasted. I think that in your example, you selected layer 4 first, then 3, 2, &1. Check it out.
Dave LaRonde
Sr. Promotion Producer
Andrew Brady
on Oct 21, 2013 at 4:37:42 pm
yep once again you have the right answer for what i need .. cheers
John Cuevas
on Sep 9, 2010 at 8:29:03 pm
AE copies and pastes in the order that you select them. Make sure you select 1, then 2, then 3 then 4..if you want them to stay in that order.
Johnny Cuevas, Editor
http://www.thinkck.com
chris straus
on Sep 9, 2010 at 8:34:03 pm
sweet. thanks.
