mask based on depth-map?
Mike van der Noordt
on Sep 9, 2010 at 2:46:27 pm
Is there a possibility to mask a layer based on a depth-map. Let me explain: I created a simple circular camera-move around a cluster of spheres in C4D, I rendered the animation out including 3D data and depth-map.
Now I want to add some animated text-layers in front of some of the spheres(actually the camera stops at these spheres for a second, and then continues..), and let it disapear behind other spheres as soon as the camera moves away from it and other spheres obscure this text...
I rather not animate all those masks seperately by hand, because there are about 50 spheres in my scene, and of those 50 spheres, 12 got text hovering around it..
I hope this question is clear :)
and thanx in advance!!!
Walter Soyka
Re: mask based on depth-map?
on Sep 9, 2010 at 3:22:01 pm
[Mike van der Noordt] "Is there a possibility to mask a layer based on a depth-map."
Here's a suggestion: how about rendering separate depth passes, recompositing them as necessary in a precomp, applying, adjusting, and maybe animating Threshold or Levels to the depth pass precomp, and using that as an luma matte for your text?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
© 2018 All Rights Reserved
