How to set Adjustment Layer to 1 thing?
Jaz Burley
on Sep 4, 2010 at 11:49:33 am
My problem is the adjustment layer is mucking the whole background up as well as the text.
If i put the text under the BG, it looks faded.
I want the adjustment layer to apply to just the text,
Thanks guys
Nick Hill
Re: How to set Adjustment Layer to 1 thing?
on Sep 4, 2010 at 2:23:54 pm
If you only need to affect the appearance of one text layer, you might be able to just apply the effects directly to the text and not use an adjustment layer. If not, then precompose all the text layers you want the effect to apply to, and put an adjustment layer at the top of this precomp.
Tudor "Ted" Jelescu
on Sep 4, 2010 at 8:27:12 pm
Or you could use the text layer to Track Matte from for the Adjustment layer: duplicate text layer, move above the adjustment layer, check track matte switch on the adjustment layer.
Tudor "Ted" Jelescu
Senior Compositor/VFX Artist
Bucharest, Romania
