Orbit Text Around Null With All 3 Axes Locked
Sal Joseph
on Aug 26, 2010 at 3:04:59 pm
I'm trying to accomplish the orbit effect of the nav menu on http://aescripts.com/
I have a 3D text layer parented to a 3D null object. I'm using the following expression to lock the x-axis of the text as it orbits around the null.
thisComp.layer("Null 1").transform.yRotation*-1;
That works fine. However, using this expression for all 3 axes doesn't work. I'd like the text's XY and Z rotation to remain 0 as it orbits around the null, as the null's XYZ values change simultaneously.
Dave LaRonde
Re: Orbit Text Around Null With All 3 Axes Locked
on Aug 26, 2010 at 4:55:17 pm
You need to auto-orient the layer to the camera. Check this out:
http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
Dave LaRonde
Sr. Promotion Producer
Sal Joseph
on Aug 26, 2010 at 6:09:05 pm
Perfect! And no expressions necessary. Thank you!
