Emergency! Need to apply and track lights to white dots..
Ed Zenon
on Aug 22, 2010 at 1:49:37 pm
hey guys,
I'm been trying to figure this one out as I'm new to after effects.
black footage with slow moving white dots
need to assign lights to each of those dots and have them track
is there a simple solution to this or am I going to ahve to do it all manually? :(
cheers
Ed Zenon
Re: Emergency! Need to apply and track lights to white dots..
on Aug 22, 2010 at 6:37:18 pm
Think I have this under control now. feel free to delete admins :)
Bartek Skorupa
on Aug 23, 2010 at 2:11:06 am
Would be good if you describe how you "have this under control".
There are people who will search for the solution in similar case and the only think they will find will be that someone "has this under control".
I personally know how to achieve this, but some people don't.
The answers are useful not only for those who ask, but for everybody.
Bartek Skorupa
Warszawa, Poland
Ed Zenon
on Aug 23, 2010 at 3:34:49 pm
I usually finish my threads with the solution if I find it. I needed to track flares onto lots of white dots and figured how to do it with optical flares, though it didnt work too well and some of the flares were off.
I actually still need to find out how to do this, so if you know a way would appreciate the help :)
Dave LaRonde
on Aug 23, 2010 at 4:17:56 pm
Please be more specific about what you need:
lights (which might require something like Trapcode Lux)...
lens flares...
or something entirely different.
Please describe what you see in your mind's eye.
Dave LaRonde
Sr. Promotion Producer
Ed Zenon
on Aug 23, 2010 at 5:31:20 pm
Hey Dave,
I basically have lots of slow moving small white dots that fade in from black and move closer towards the screen. I need to add subtle flares to each of these lights.
The way I was thinking was to track a light to each dot and then just apply the flare to the light. Though not even sure how likely that sounds as I am really an AE novice.
I tried the luminance option in Optical flares, though this tracked flares onto the dots instantly, quite a few were off track.
so I'm back to square one :\
