simple expressions
dan brazil
simple expressions
on Aug 20, 2010 at 11:33:56 pm
Hello i want to animate an object from one key frame to another. But i cant because I've applied an expression to that property.
I have an effect called cc sphere.
I want to animate the y rotation.
But i already have an expression:
I have done abit of research and think i need this function to animate: setValueAtTime. But I have no clue how to implement it.
I have just completed a video copilot tutorial:
Thanks daniel
Michael Szalapski
Re: simple expressions
on Aug 23, 2010 at 1:56:21 pm
I haven't watched that tutorial, but I'm assuming your planet texture is in a precomp, if that's the case, you can simly use an offset effect to move the map in the precomp. It'll then look like it's spinning in the main comp.
- The Great Szalam
© 2018 All Rights Reserved
